Old 05-12-2011, 04:08 PM   #47 (permalink)
mcguire
Twuck - '06 Ford F-150
90 day: 17.82 mpg (US)
Rudolph - '95 BMW R1100 GS
90 day: 35.37 mpg (US)
Terrifying - '02 Chevrolet Corvette Coupe
90 day: 28.4 mpg (US)
Big Red - '13 Ford F-150 XLT
90 day: 18.96 mpg (US)
Originally Posted by capnbass91 View Post
isn't that idea a fact? when over-inflated only the middle of the tire will have contact with the road and that part will wear out faster than the outside; it will wear unevenly.
This is exactly what my F-150's tires do if inflated to the sidewall pressure (45psi, IIRC). It took a couple thousand of miles to become obvious. On the other hand, they are fine at 42psi front/40psi rear and rotated regularly.
A vehicle with a better weight balance or with less of a difference between normal load and max load probably would not show as much of a difference.
