Old 05-12-2011, 11:45 PM   #2 (permalink)
Frank Lee
Originally Posted by actwithclarity View Post
Even if you care about fuel efficiency above all else, MPG is just a vague number that should be taken with a grain of salt. It is only useful as an absolute statistic if you are driving on a set route.
Not so. It provides the driver with a benchmark to try to surpass, regardless of route. It also can provide the driver with an indicator of the vehicle's state of tune- if the gaslog shows a sudden variation that is otherwise unexplainable, it is prudent to go give the vehicle a check-up. And of course it provides a figure to compare one's own performance with that of others.
