Old 05-13-2011, 04:21 AM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by moparrr07 View Post
both is obviously a great answer but will you loose all effects of the belly pan with an air dam?
You won't.
Even with an air dam, there's a lot of air going underneath the car , and it's still going to interact with and cause drag on the belly of the car.
If you run an air dam down to the level where you could fit a belly pan, that would be close to optimal.
