Old 05-13-2011, 03:41 PM   #37 (permalink)
aerohead
inter-library loan
Originally Posted by mateospeed View Post
I don't have a scangauge, or anything like it. I'm hesitant to buy one, since I'm planning to ditch this Tow Vehicle and go to a diesel manual when possible. I'm assuming the scangauge will not transfer to a diesel, but this might not be a good assumption. I've been doing my best to judge the load on the truck, whether or not to unlock the coverter ascending hills, etc. Transmission temp never seems to change much, perhaps because it has a giant cooler, and is a 3/4 ton to start with. I very rarely use cruise control, btw. It almost always throttles up, drops into 3rd and unlocks the converter when starting uphill, whereas I would rather not, unless it's a very long, steep hill.
Perhaps I'm not being clear on the way I'm approaching the problem. I'm considering 2 different thought paths: one of seperate truck and trailer bodies, and one with a connected truck and trailer.
If considering seperate truck and trailer, its seems a viable thought path to consider the trailer to have a Cd of near 1.0, but only be partially wetted, if that makes sense. If it this is simply an incorrect way of thinking, then that's acceptable, and I'll drop it. When adding a bed cap, you would effectively reduce the "effective" frontal area of the trailer.
Now, all that said, I've come to a realization: none of that makes sense. All vehicles have some gaps in them; even the truck has a gap b/w cab and bed. The seperate vehicles and effective frontal area approach does not follow accepted aerodynamic principles. I will indeed drop that thought path. Thanks for helping me get there!
SO, what I'm looking at are different ways to reduce the Cd of the entire rig, by smoothing the transition from one frontal area "block" to another. That makes more sense. Now, where's the smiley with a lightbulb?!
My library is pathetic. "we don't have it." Is about all I'm getting. No response to "can you get it," "is a transfer possible," or any talk like that. They looked at me like I was completely out of line for suggesting such a thing. Perhaps I approached it from the wrong angle... time to send in the hot wife:-)
-Matt
Your librarian should be able to do a inter-library loan in which you just pay for the postage to mail the book back and forth,unless the book is strictly a 'reference' item,which,if so,cannot leave a library.
If that's the case,they should be able to locate the nearest library which has the book.
If 'reasonably' close,travel there,and use the library's copy machine to reproduce the materials you need.I did this with Fachsenfeld's book.
If those people have a degree in library science they should be stumbling all over themselves to help you.If not,you may contact your city manager or mayor and suggest that those personnel are under-qualified for their taxpayer-supported job.
