Old 05-14-2011, 09:19 AM   #2 (permalink)
Daox
Air going through a radiator is made turbulent by the radiator on purpose to increase heat transfer. If you straighten the air you diminish the pressure differential between the front and back (thus decreasing drag) and also decreasing the cooling capacity of the radiator.
