Old 05-06-2008, 11:41 PM   #11 (permalink)
Lazarus
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
Originally Posted by capn View Post
my goal with a restrictor plate is not to limit my power use, rather the engines output and consumption.
I am also not trying to reduce pumping losses, this is just adding more restrictions in hopes it might trick the MAF that the engine needs less fuel. Although testing is required.
I would say Metro's right.
I tried a restrictor plate with no luck. I reduced the intake to a hole about 1" in diameter. There was an increase in FE but the car was undrivable.The top speed was 55 mph( took 65 seconds to get there at 85% throttle position, just before open loop) but the acceleration rate was unsafe. If I increase the diameter to where I could accelerate the FE advantage went away. YMMV (Your mileage may very.)
"Judge a person by their questions rather than their answers."
