Old 05-14-2011, 03:27 PM   #285 (permalink)
Kodak
Kodak's Avatar
Canyon - '07 GMC Canyon 2wd regular cab
90 day: 24.95 mpg (US)
71 or 73?
Tip 71 means that when you're reversing, come to a complete stop before trying to go forward. Likewise, stop all forward motion (brake) before reversing. If you don't come to a complete stop, then you're using extra engine power to overcome the momentum of the vehicle. Think of it kind of like starting 'in the red.' Instead of just starting from a dead stop, you have momentum working against your intended direction of travel. Using the brakes at least brings you back to a complete stop.
Tip 73 - Cruise in the highest gear practical. Often, a given speed can be maintained on flat ground in one of a few different gears. Less fuel is used when in the highest gear (lower rpm). If you're going too slow for a certain gear though, you can hear the engine sort of struggling or shaking a bit. That's too high of a gear.
Hope this helped. You probably already got 73; I think it was 71 you wanted clarification on. There's an answer on pg 28 too. Right before I went ahead and changed the topic on you dieselbeetle.
The Following User Says Thank You to Kodak For This Useful Post:
SwamiSalami (05-14-2011)
