...see Fig. 10-7, on page 247, of "The INTERNAL-COMBUSTION ENGINE, 2ed., 1961, International Textbook Company, by Professors C.F.Taylor and E.S.Taylor of MIT:
Fig. 10-7. Volumetric efficiency vs. mean piston speed and Z of the MIT geometrically similar engines under similar operating conditions.
...it's a graph showing that Vol. Eff. "peaks" at piston speeds between 1000 and 1500 fpm, which corresponds to Mach index air-flow Z numbers of 0.3-0.4-0.5.
...Z number is tied into both piston speed and valve size (ie: trying to suck/push air past/though changing valve areas), which gets into Mach index (Z) and maximum air speeds...but, piston speed 'starts' every thing.
addendum: see posting #53 below
