Thread
Compression, turbos, and efficiency
05-14-2011, 11:19 PM
27
permalink
bwilson4web
Engineering first
17 i3-REx
- '14 BMW i3-REx
Last 3:
45.67
mpg (US)
Blue Bob's
- '19 Tesla Std Rng Plus
Found an interesting post in USENET to complement this thread. In particular, the first link
Originally Posted by
Bruce_Richmond
Funny, I just used some of the same links in a discussion in
alt.global-warming.
Should switch gasoline to 100% ethanol/You switch, retard. - alt.global-warming | Google Groups
(This included a useful engine calculator:
Power Cycle Analysis Online Calculator ...
This allows folks to change different ICE parameters and see the effect. rjw)
I agree the p-v chart is wrong and the normal transition can be seen
in figure 3.8 of your previous link.
http://web.mit.edu/16.unified/www/SP...oIdeal_web.jpg
The horizontal line from 3 to 4 is usually used in the cycle of a
diesel. The rational is that in a gasoline engine the fuel burns
almost instantly giving a vertical line for the rise in pressure.
With the diesel the fuel is injected over a period of time which
mantains a constant pressure during the first part of the power
stroke. Here is a p-v diagram for an Atkinson diesel:
Ern's Blog
Here is an article that gives some info about how the Atkinson cycle
is applied to the Prius.
Hybrid Tech - Honda's Insight and Toyota's Prius - page 2 | Automotive Industries
I also found out that a true Atkinson cycle engine involves more than
just variable valve timing, it actually changes the lengths of the
strokes, thus avoiding the pumping losses of drawing air in and then
pumping it out before closing the intake valve.
Animated Engines, Atkinson
Still the valve timing trick is a lot better than nothing.
Some of the articles are a little dated such as the 1.5L Prius engine analysis. Still, it is a good collection of URLs . . . Thanks to Bruce Richmond.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus
- 215 mi EV
2017 BMW i3-REx
- 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
bwilson4web
View Public Profile
Send a private message to bwilson4web
Find More Posts by bwilson4web
