Old 05-15-2011, 07:26 AM   #1463 (permalink)
peppp
the answer is almost always the same : uprated springs (a uprated spring with the same length won't be as low as a regular one) make sure the shock absorbers are decent before you change the springs, tho.
just made a quick google search and could only find lower springs for the metro ... maybe find a shop that custom builds those?
btw try googling "suzuki swift higher uprated springs" .. its kinda depressing, lol
EDIT: maybe "higher" coilovers would do the trick.. but you need to check with some performance specialist to get the right ones. They are usually pricey and will make your car hard as a rock.
