CRX HF rims are steel 13" by 4.5" wide rims, where most older civic and CRX rims are 13" by 5" or 14" by 5.5", the steel HF rims are also 12-13 pounds, so a few pounds lighter then average steel rims but if you really want light narrow rims go with the Civic VX rims they are 13" and I think 4.5" wide alloy rims, only draw back is it's harder to put moon caps on them as they don't have the lip that holds most hub caps on.
Honda Insight rims and Civic HX rims also will bolt on to your car and are light weight, the insight are already smooth so you don't need hub caps on them, draw back of them is that they are 14" and tires are hard to find without going with a larger/taller tire.
