Originally Posted by Christ
The very first CRX Si wheels were 13", weighed 10lbs or less, and were fairly smooth.
I wasn't aware of those rims, a nice option altho very hard to find at junk yards, if you get the 14" insight rims and stock insight tires, you will be close enough that your speedometer should be pretty close and you will have nice low rolling resistance tires, insight rims can take a bit of searching to find as well but are more common and are newer, they also look really slick.
