Old 05-16-2011, 02:55 PM   #1 (permalink)
JR1
f150 successful mods
Here are mods that improved gas mileage on my 2000 f150, 4.6L motor and 5 speed manual :
I installed a k&n filter with the FIPK long tube and a helical throttle body spacer when the truck had about 20,000 miles on it. Gas mileage improved by 1.5 mpg. Engine respose and power increased noticeably. That was 100,000 miles ago and the fuel savings have been constant. I don't think there is anything magical about the K&N filter-it was the FIPK tube , removing the old restricive airbox that did the trick. Any decent large cylindrical air filter on the end of the FIPK tube would work.
I also installed a Gibson exhaust about 2 years after the FIPK tube- no measurable improvement in gas mileage or engine power.
I've also found that a hard tonneau like a roll-n-lock is about 0.5 mpg better than a canopy.
In a back to back test, I found that the 5 speed manual got 3 mpg better than the same truck, same engine but a 4 speed automatic. Downside : you lose a LOT of towing capacity with the 5 speed manual.
JR1
