* Make the body wider so it completely shields the rear wheels from the air stream.
* The down- and inward curvature of the rear body / rear wheel fairings is too fast, and causes additional drag. Give it less curvature, with a sharply defined railing edge where the air can detach cleanly.
* Add a (partial) boattail aft of the roll cage / driver helmet.
* Round off the frontal edges of the body, right behind the engine.
Have you made any mods to the other dragster, and did they improve your time / end speed ?
