Old 05-16-2011, 06:29 PM   #18 (permalink)
beer
Originally Posted by robertsvx View Post
A vacuum gauge & the dead peddle zone in lean burn is where I found the trick to better mpg.I can maintain 60mph in lean burn with vacuum at 8", let off gas to about 15" & still maintain speed.completely different from conventional peddle habbits on non lean burn engines.and hard to do if im not thinking about it.
Yeah it will work, but accuretcy is not as good as directly tapping a signal from the ecu.
Originally Posted by wyatta4 View Post
So what can I do in my situation?
I plan on putting a 92-95 VX motor in my 91 crx dx.. Can I do a light such as this?..
As i recall there was a topic about a lean-burn indicator in a OBD1 D15z1 engine.
