Originally Posted by Heihetech
 That's great! Your deep understanding has reached the key point -----
Windband oxygen sensor will guide ECU to close the fuel control loop at
higher Lambda points (Normolized air-fuel ratio). This means less fuel
will be burnt when DCD is on, the reason of fuel saving.
If you have just the one O2 sensor controlling all the cylinders, won't the injectors still be squirting fuel into the deactivated cylinders, just less of it? Wouldn't this would cause the active cylinders to run lean?
Should you not have the computer cut fuel & spark to individual cylinders on a rotating basis?
