Is Z supposed to be the port velociy, or the valve opening velocity?
I ask because the equation takes into account valve diameter, but not valve opening.
I noticed that there is no parameter for manifold pressure, wouldn't that affect the actual mach number? Or does it mean that at lower throttle (lower manifold pressure) that a lower velocity/rpm is desireable?
