As I have posted, the o2 sensor is a WIDEBAND OXYGEN SENSOR. It will
cheat ECU to close fuel loop at higher Lambda point, resulting less fuel
injected. The regular o2 sensor no longer works under DCD control. It
must be replaced with a WIDEBAND OXYGEN SENSOR.
