Originally Posted by minAirForce
New to this. Do you totally want to block the air under the car? Don't your want the high pressure air under the car to meet the low pressure air in the rear?
If you have a smooth belly pan covering up the under-body, you don't need
a large air dam. (Just some shorts ones for the wheels).
But normally, the underbodies of cars have all kinds of non-aerodynamic
junk hanging down in the air-flow..
So, sometimes, there is a need to keep the air flow off that
junk..
