Old 05-17-2011, 04:37 PM   #10 (permalink)
zonker
500 Mile Metro Traveler
'89 Dakota LB - blue - '89 Dodge Dakota V6 LE
90 day: 19.8 mpg (US)
'17 Fiat 124 - SunFiat - '17 Fiat 124 Spider Classica
90 day: 30.51 mpg (US)
'89 Metro - The Egg - '89 Geo Metro Base
90 day: 50.71 mpg (US)
'94 Alto - The Box - '94 Suzuki Alto Ce-L
90 day: 39.5 mpg (US)
Originally Posted by cleanspeed1 View Post
Maybe we'll have to go next level with the motor, and since it is an OHC motor it just makes life way easier.
How about a cam swap, something that can boost the bottom end torque.
A tri-y header ( 4-2-1 ).
Programming the ecm.
Synthetics front to back.
good points - checking into a lot of that.
my dream project would be to grind a cam with a atkinson style of profile (huge intake duration, short exh duration) but i'd only do this if I milled the head for increased compression ratio since atkinson motors are half again as much as a typical gas icm's. But since I'd be dealing with a engine tuning learning curve from hell, i might not attempt this any time soon.
so, as a cheaper alternative, there is a factory mustang SVO turbo cam that adds a little lift and duration to what i already have so I might give that a go first with an adjustable cam gear.
the factory cast manifold is a 4-2-1 design, and no aftermarket company makes a CARB compliant header for this application (I'm in smog nazi california)
re the ecu upgrades, i need to polish up on my eec tuning skills. Currently that is way over my head, so i'll probably resort to a wide band o2 sensor and gauge, and tweak the sensors to give me the kind of numbers i seek.
i have changed out the oil to a 5w30 mobil 1 from 10w30 dino, and might look to do something similar in the diff, but i don't see any benefit in messing with the recommended atf, other than a trans cooler.
