Old 05-18-2011, 12:43 PM   #18 (permalink)
SentraSE-R
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
My personal comparison will have too many variables to answer the taller tire question, The best way to test just taller tires would be to find another xB owner with stock steelies, buy taller tires of the same brand and model for my old wheels, wear them in, and then do the ABA testing with the tires from the other car to swap between tests. That would be hard to pull off logistically.
But I want to answer the basic question for myself, even knowing I'm throwing in different wheel sizes, wheel aerodynamics, heavier tires, different inflation pressures, effective gearing variation, different tire compounds, different tread patterns, wider tread width, etc. Most of the significant differences work against my new wheel/tire combination. I can still pose the question: do taller tires improve mpg despite all these other factors stacked against them in this testing regimen? Actually, I guess the question is: what results will I get with my taller, heavier, less aerodynamic tire/wheel combo compared to stock?
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
