Old 05-18-2011, 09:30 PM   #4758 (permalink)
harlequin2
Is this the 500A controller you are discussing?
Mine has been working fine with a charging voltage of 162V and I also modified the software somewhat to increase the current to a bit over 600A by scaling the sensor o/p. It handles those numbers without any problems. The serial data still thinks its 512A max though, so you have to do a bit of mental arithmetic if you want the real current from RTD.
Sometimes I sits and thinks and sometimes I just sits.
