Old 05-19-2011, 01:14 PM   #4 (permalink)
Nevyn
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
You can program an X-Gauge on the ScanGaugeII to show in/out of lean burn. Problem is, the math they use to calculate MPG isn't very accurate on lean-burn cars. Even so, you WILL be able to watch lean burn, throttle position, ignition timing, engine load, coolant temp...although the instant MPG may be off, it'll still give a number. Trying to get a wrong number as high as possible is still better than no feedback at all!
