Old 05-20-2011, 11:29 AM   #8 (permalink)
NeilBlanchard
Thanks Bill. I really have to do the work on this first prototype in the "positive" mode, and this means I need to work with EPS, which means I have to work with epoxy. And I think by your description, that I will need to work with the slow setting epoxy.
Reading the description on US Composites site, it would seem that once the epoxy is spread on the form, you then have a longer time to work with it -- it is the "pot" time that is quite limited; even with the slow setting epoxy.
