Originally Posted by CapriRacer
For Standard Load (SL) Passenger Car tires, there are 3 possible pressures on the sidewall: 35 psi (where the max load occurrs), 44 psi, and 51 psi - the last 2 of which could be considered over-inflation.
I asked Michelin folks about the max. pressure for their Alpin A4 winter boots, as I couldn't find it on the tyres, and got back that it was 3.4 bar / 49.4 psi .
No strings attached, no
"don't do it", no
"you're going to kill yourself".
