rocket man, if you would read the thread on the mythbuster's tire test, your mileage gains are minimal past a certain inflation. And you are running your tires seriously over-inflated; it's very risky to keep them inflated that much over the maximum rated pressure.
It's not the same a bicycle tire. Bicycle tires are rated for 120psi because they have very little area to pressurize, unlike a car tire. The maximum sidewall pressure is there for a reason.
My VW tires are rated for 44 psi, running at 40 psi.
I have two vehicles with LT tires rated for 80 psi, running at 42 psi.
My truck placard recommends 29 front, 35 rear. Similar for the other vehicles I think, I don't pay it much attention.
I'm not coasting, I'm shifting slowly.
