nope, checked the coolant and the level is good, i'm thinking the problem is the damaged radiator, most likely a couple passages are pinched and aren't flowing as much as they should, i'll probably flush the system out first, i'm sure it's due for that by now. The family and I (girlfriend and my parents) are heading down to Indianapolis next weekend to the Indy 500, that will be the first long distance road test for the pan and ducting, hopefully it all works out well.
