Old 05-21-2011, 01:12 PM   #166 (permalink)
aerohead
sides/belly
Originally Posted by orbywan View Post
More good information, thanks aerohead. I kept looking at the side deflectors on the semi's on the road and wondering exactly what the goal was there. Duh.
The undercarriage of my RV is obviously different that a semi's trailer, but do you think I should try the same approach, long diverter pushing the air to the outside of the each wheel set? That would be assuming no belly pan.
With a belly pan, would the general design be the same do you think?
There are two schools with respect to sides:
(1) make the flanks of the vehicle flush with the outside of the wheels and put a smooth wheel cover on.Allow some ventilation of the cover to help brake cooling on mountain downgrades.
(2) inset the wheels a bit,allowing a full skirt to be added.Provide shark gill exits to blend brake cooling air along the sides of the rig.
The belly would be done as any.Renault demonstrated a 17% drag reduction with a full pan on VIRAGE.
Fachsenfeld got an OMNIBUS inter-city bus into the low Cd 2s with a pan.Under Cd 0.2 with inflated tail.
------------------------------------------------------------------------- On low drag vehicles the wheel drag can be half the drag.It's worth going after.
See what you've got and maybe take the easiest path.
PS,I looked up the Omnibus in Hucho's book.This is actually the first K-Tail,the K coming from Koenig in Fachsenfelds name.He beat Kamm to the patent office.Although Carl Breer had done a 'chopped tail' in 1934 with Airflow.
The bus,with inflated boat-tail had Cd 0.158.
