Well we already have some of that implemented in the "bauer-code" already. If the device came out of saturation isnt that almost the opposite of falling short circuit? ie the load is so large (short) that it cant get into a fully conducting state? Not a big deal in any event. I would like to look at a brake input sometime. I'll implement the hardware as i have the controller on the bench. Would be a neat feature and would eliminate the stuck acccelerator / failed potbox issue.
If brake signal high then ignore throttle and command pwm to zero. Check current. If more than 10amps open contactor.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
