No cams. The valve train is also stock. Because I thought heads needed all new valve guides and seals, so while it was all out I had them ported and polished.
My car started off as a 4 speed auto and I just recently made it 5 speed manual. I also have a 13lb lightweight flywheel (stock is 26lb), stage 1 McLeod clutch, Steeda Tri-Ax short throw shifter, and an aluminum driveshaft. I say all that because I probably wont go 6 speed just because of the cost. Seeing how I just swapped all that stuff within the year.
Some mods I wanted to do were belly pan even if its not a full one. Maybe one that extends back to the firewall. Side mirror delete and convex mirrors mounted inboard. Front grille block off. Lexan fog light covers much like the modified Metros run. Possibly a cowl hood because my hood has the 2001-2004 hood scoop.
