Old 05-22-2011, 03:09 PM   #2 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
At a hundred grand you may have some plug wires breaking down. Spark plugs pretty much last forever since tetraethyllead went away. Electronic ignitions don't wander like old-school distributors did., but underhood heat still breaks down insulation.
Check your brake pads. Everybody uses sintered metallic brakes these days. When iron rusts, it expands. You may have rust at the edge where the rotor doesn't wear off the soft, weak ryst and brakes may be dragging. Also re-lube the caliper slide pins. They get get dry and cause brakes to drag.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
