Old 05-22-2011, 08:06 PM   #6 (permalink)
ngrimm
Thanks to all of you for your replies. I was thinking about tapering the belly pan from just under the front bumper under the suspension and transfer case thus eliminating the air dam. The gas tank is behind the rear axle and tapers up. I was also thinking of removing the side skirts and angling filler panels from the rocker panels down to the belly pan since that part is still uncovered.
