Old 05-22-2011, 09:14 PM   #1 (permalink)
JohnNeiferd
Johnny's Metro - '93 Geo Metro 4-Door Hatchback
90 day: 47.5 mpg (US)
Jetta GLS TDI - '01 Volkswagon Jetta GLS
90 day: 45.83 mpg (US)
MPGuino: Max Current for VSS Line?
Hi,
My question: What is the maximum current the vehicle speed sensor line (for the MPGuino) should see? 0.25 amps? more? less? I want to make sure I don't let to much current through the new vss wire and damage my MPGuino. Is there a minimum required current for the MPGuino to pick up the signal? If so, what is that minimum current?
Long story short, I am adding another VSS signal for both MPGuino and my aftermarket cruise control in my vehicle instead of using the stock VSS signal.
My stock VSS is a reed type switch. An open switch has +12v on one side and ground on the other and magnet from speedometer makes the reed switch make contact and completes the +12v circuit.
I am making a similar system using a bicycle speedometer magnet sensor, and two magnets on my cv shaft. It is basically a reed type sensor, open circuit without a magnet, and completed circuit with magnet. I am going to feed +12v to one side of the wire, and the other wire goes to ground. I'll be using a resistor to limit current flow through the wire.
My question again...: What is the maximum current the vehicle speed sensor line (for the MPGuino) should see? 0.25 amps? more? less? I want to make sure I don't let to much current through the new vss wire and damage my MPGuino. Is there a minimum required current for the MPGuino to pick up the signal? If so, what is that minimum current?
