Originally Posted by rocket man
According to what most believe, I am running my tires with way too much pressure, but I did the research and tested myself and found I get noticibly better mileage with the higher pressure. At 70 psi , I am only 19 psi over what is listed on the sidewall. That is nothing to be worried about at all. . . .
My understanding is police crusers also run over max pressure tires. It gives them more precise handling, longer life, and a little more performance from the lower rolling drag.
In my case, maximum sidewall pressure, 51 psi, accomplishes my goals so I'm happy. But I would have no problem with running up to 60 or 70 psi.
Bob Wilson
