Be sure to do the timing belt, asap. These engines are interference style, and the carnage is nothing nice. After that, check the valve clearances, change out all the fluids and filters and run a good diesel treatment. I like the Service Power cleaner with boost ( silver bottle ).
Before you start running the waste oils, you should do the injectors and make sure that the pump settings are right. Make sure everything is proper and you won't have to look at it again for a long, long time.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
