Old 05-23-2011, 03:46 AM   #163 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by euromodder View Post
Proper used oil drainage from these 1.6HDi engines is apparently crucial, according to the C4owners.org FAQ .
You might want to read up on that, Piwoslaw ...
Same engines, same troubles.
Thanks, I'll have a look. My mechanic gravity drains, I doubt he has one of those oil vacuum thingies.
This reminds me of something funny - Once I was looking through the specs of different Peugeot models with the same 1.6 HDi engine and I noticed that each manual gave a different amount of oil that engine could hold. I don't remember the actual numbers for each model, but they spanned from 4.2 to 4.8 liters. That's quite a difference for the same lump, so maybe there are some differences between the 1.6HDi in a 2005 P307 and the 1.6HDi in a 2008 P207, for example?
Getting home from the fuel station by the low speed route and using long coasting, I managed 3.4L/100km (69mpg) on both the OBC and the ScanGauge AVG !
Maybe it's time to start avoiding the motorway ?
Is the slow route longer? Ever since I started looking at fuel used, instead of just l/100km, the only times I take my old (faster) route is when biking
BTW: My SGII shows 99 as max LOD, not 98.
