Old 05-23-2011, 07:15 AM   #5 (permalink)
Bennett_Racing
Novice but learning!
Originally Posted by euromodder View Post
* Make the body wider so it completely shields the rear wheels from the air stream.
* The down- and inward curvature of the rear body / rear wheel fairings is too fast, and causes additional drag. Give it less curvature, with a sharply defined railing edge where the air can detach cleanly.
* Add a (partial) boattail aft of the roll cage / driver helmet.
* Round off the frontal edges of the body, right behind the engine.
Have you made any mods to the other dragster, and did they improve your time / end speed ?
Same reply, I will try to widen the body with struts to shield the rear wheels,
I may in the future tweak the body but for now will stay as is
front edges of the body 'should' be covered by the engine.
as for the other car rebuild is still ongoing, but its looking superb!
