Old 05-23-2011, 08:23 AM   #9 (permalink)
Drew
Sorry for the delay in response but thanks for all your guys input. It sounds like the ultra-gauge is the best fit for my Civic HX. When you say the MPG are not true or accurate is it real far off? Like in tenths or like actual miles off? Just curious. I checked my tire pressure and put all the tires at 45 psi, they were at 35 psi. I'll see if this makes any difference as well. Also when running the ulta-guage what will I look at to know if I am in lean burn? Most likely it's the MPG, but is there anything else I should monitor?
