Bit more info. Just spent the past half hour fault finding. Upgraded to v1.3. No change. Removed the pic and put a meter on pin 22. The 5k pot varies this between 0 and 5v. Scoped pin 13 (fuel pwm). In setup mode , the pot has no effect on pwm. In normal mode no effect either. Looks like we have a pwm bug in the code for the 2480. No doubt this is what's been causing my problem with the bmw fuel gauge also.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
