Old 05-07-2008, 05:22 PM   #59 (permalink)
larrydag
FuelSipper
HondaHokie - '95 Honda Accord DX 4 door
90 day: 26.91 mpg (US)
PCB arduino shield mock-up
I quickly mocked up a possible pcb mock up for an arduino shield to combine all of the components needed to interface with the LCD, buttons, and VSS/Injector cables. This was a quick run so it needs to be debugged. I figured I would post it and get any feedback.
My thought is that header pins could be soldered into this shield so it would just plug right into the *duino. This design I don't believe is capable using Radioshack type supplies because the traces are a little too compact. But I bet you could use Radioshack supplies if you took out some traces and replaced it with jumper wire.
I did the layout in Visio 2003
