Old 05-23-2011, 12:40 PM   #8 (permalink)
PaleMelanesian
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I swapped it yesterday into the Odyssey for the day.
Unplug
plug
set engine size
speed calibration is the same on both, but in any case it's only a couple clicks
quick fillup procedure
set fuel calibration if needed. I don't.
drive
Then I did the same this morning back into my Civic. The hardest / longest part of the process is stringing the cable so you don't trip on it. Once you know the calibration it's quick and easy. I use 1.8 engine size vs my actual 1.6 to get my 12.5% offset. It takes fewer clicks that way. The Ody is dead on at its actual 3.5 engine.
Fuel capacity is irrelevant. It only affects the Miles to Empty gauge. I have a fuel gauge in the dash so I just ignore that.
