Originally Posted by apowers
I am using the 2480 and the fuel gauge matches the LCD. There is just a delay before the gauge goes all the way up to full. Just on the reset after that it is alright till the next reset. It also does not take the reset on the LCD if I don't drive away briefly before turning the key off.
Hey Alvin, thats funny. I just found that bug yesterday and didn't get to post it. Basically, when you reset SOC, it will update the capacity in ram immediately, but still relies on the 1 minute timer to update the new ram value to EEPROM (hence your little required drive). Don't have code in front of my but solution is simply adding line "Call Capstore" in the section of code after "Reload" label. Resetting SOC will then update capacity and immediately write it to EEPROM. I will post tonight.
-Chris
