Originally Posted by tugboat
@BamZipPow - where'd you get the thermocouples and digital readouts?
Thermocouplers came from Thermoworks...
ThermoWorks High Temperature Thermocouple Probes. Use these probes to measure temps above 600°F
I have 2 different ones...the Washer Thermocouple and the High Temp Industrial Probes (1/16").
You can find other thermocouplers from other companies on the web, too.
I found some 12V (AC or DC) temperature switch controllers at LoveControls.com
Table of Contents -- Temperature Controls
I used the TCS-4030...and I run them on a 12V voltage regulator (got it off of eBay) to make sure they git 12V vs what the alternator is putting out.
Series TCS - Thermocouple Temperature Switch - Dwyer Instruments
