Originally Posted by cactus jon
I have also noticed a slight stumbling at low rpms under load. Was the EGR system hard to disassemble and clean?
The EGR "herky-jerky" is anything but slight, at least when it's fully developed. (You might have an early case, or it might just be normal behavior.)
The EGR valve is easy to remove & replace, but not so easy to disassemble & reassemble. But IIRC a new valve assembly is about $120 or so on-line.
