I'm new to the forum, so I hope it's alright to post this kind of ad in here.
My company sells fuel injector connectors for attaching a custom wiring harness to your injectors. We have the EV1 style injectors in stock and most other styles available on a limited basis.
Male and female connectors, with pins and seals. $5.00
Connectors with high temp wires installed in your custom configuration (setup to read injector signal or setup to be able to disable injector, etc.) up to 6" wire leads. $10.00
Email us if you're interested. Or check out our website (under construction).
Alternative Fuel Conversions, Inc.
Thanks!
Mike Black
Owner
Norman OK
mike@alternativefuelconversions.com
