Old 05-24-2011, 05:42 PM   #8 (permalink)
Arragonis
The PRC.
Originally Posted by cleanspeed1 View Post
Have you run some regular diesel through the system with a strong cleaner? I don't know what you have available that is reputable as far as cleaners are concerned, but give it a go before tearing into the motor to rule it out. I am hoping it's something simple.
I'm probably wrong but I think I heard (on a youTube video) DrDave suggesting using Bio actually released crud from your system and so you shoudl change your filters more if you use it than regular fuel.
In this case though it sounds like a comp-test may be suitable. May also be worth running the engine with your hand over the open oil filler cap and checking if you get pressure there too. If you do then the crank case is pressurised which may mean a bore / ring issue.
(Disclaimer - this is from my old classic "is my Mini a-series engine knackered or not" days...)
