Old 05-24-2011, 05:51 PM   #18 (permalink)
Bajascoob
BigWhiteWhale - '01 Ford F250 Lariat Crew Cab Superduty
Found some non-3m film that is a bit thicker, and on sale (early spring clearance of winter stuff). I wasn't really happy with the bed mounts before so I redesigned them, for easier access/install/removal. I double nutted the bolts in the be rail, so the nut and bolt always stays, and I just have to put the top nut on to install. I welded hinges in place of the clamps. On the driver side I removed the hinge pins and replaced them with "hair pin" for quick tilt up access. The "sliding glass door" size isn't big enough so I seamed it with the included tape. Previously I left triangle seams, this time I'm living on the edge and went straight across the back, it's a bit cleaner this way.
ID:	8449   Click image for larger version
ID:	8450   Click image for larger version
ID:	8451   Click image for larger version
