It sounds like the MPGuino is the the best way to monitor my lean burn. Since it is the only true way to track the MPG. I've seen the instructions on installing a phone jack as a terminal port for the MPGuino. Is it best to splice these connections at the ecu or at the end points of the cirucits? All advice is welcome. I dont want to screw up anything! I've been looking for some easy to follow steps. So if there is a site or link you know of please pass it along. Any success stories would also be good. I'm going to try to find my electrical wiring diagram for the 1999 civic HX engine d16y5.
