Old 05-25-2011, 09:53 PM   #17 (permalink)
Hubert Farnsworth
Hubert Farnsworth's Avatar
Planet Express Ship - '94 Geo Prizm LSI
90 day: 36.57 mpg (US)
Originally Posted by Phantom View Post
Replace the cabin air filter and clean the passages under it, also clean the vents and as far down the vent as you can. I hope that the last owner did not smoke with the air recirculating in the car.
Just a small technical point, the evaporator core is inside the hvac module and is used to evaporate the refrigerant, pulling the heat out of the air before it enters the cabin, the condenser converts the hot and evaporated refrigerant gas into a liquid and is typically mounted either just in front of, or just behind the radiator behind the grille opening.
