Old 05-26-2011, 01:13 AM   #60 (permalink)
crmears
Originally Posted by orbywan View Post
I have a question regarding boat tails for everyone if I may. I'm building a 5 foot boat tail for the back of my RV. My question is; over the 5 foot length of the tail, how much bow should the sides have?
I'm guessing from my flying days that the best shape for the sides of the boat tail should be shaped very much like a wing, bowed in the tightest arc possible, or close to it, that will allow the air to adhere to the curve, ala the Coriolis effect, without having separation of airflow on the boat tail surface.
If that is true, can anyone tell me how much curve to put in the tail surfaces?
Thanks. I thought I was going to whip up a quick test cone to see what the results were. Ah, grasshopper, you have much to learn.
I do not think that we should attempt to copy the shape of a wing. Wings are designed to use airflow to create lift. The action of creating lift with a wing induces drag. The best thing to copy is the fuseloge of an airplane. Euromodder might be correct. Flat panels might give you the same basic result. Of course you would need to round the corners where the top and sides meet.
Randy
The Following User Says Thank You to crmears For This Useful Post:
orbywan (05-26-2011)
